Configures a trusted neighbor policy to determine trusted RIPng router neighbors for the interfaces on the switch running RIPng.
vlan-name | Specifies an IPv6 configured VLAN. |
tunnel-name | Specifies an IPv6 tunnel. |
policy-name | Specifies a policy. |
none | Removes any trusted-gateway policy from the VLAN. |
None. Control packets from all of the neighbors are processed.
Use this command to set a policy to determine trusted neighbors. A neighbor is defined by its IPaddress. Only the RIPng control packets from trusted neighbors will be processed.
The following policy designates neighbors from the fe80:202:b3ff:fe4a:6ada:: /64 subnet and the neighbor at fe80:203::b3ff:fe4a:6ada as trusted gateways:
entry filter_gateways { If match any{ nlri fe80:202:b3ff:fe4a:6ada:: /64; nlri fe80:203::b3ff:fe4a:6ada:: /64; } then { permit; } }
configure ripng vlan backbone trusted-gateway nointernet
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
